PMTeam@ZWO Upload the error log as shown in the following picture, provided that the ASIAIR is not shut down after the problem occurs.
In addition, if you have downloaded v2.3.1 and adding a USB Hub between the CEM40 and ASIAIR Pro does not solve the problem, we also recommend that you try the method in the following link to install and activate an OS we prepared for Pro to see if it can solve the problem, thank you.
Link: https://bbs.zwoastro.com/d/12655-how-to-connect-the-new-sky-watcher-eq6-r-pro-to-asiair
