Support@Seestar
Today I down-loaded the app & firmware updates (ver 2.6 & 5.34). Despite the full moon, I just tested the system on NGC 7000 (N America Nebula) with framing set so that "Mexico" is at the bottom. The framing window lined up nicely without an angle adjustment (i.e. 0 deg),
I have not (yet?) used plan mode.
Unfortunately, the mosaic framing bug in EQ mode has NOT been fixed. The "Mexico" portion of the image is at the left side of the image frame instead of the bottom and thus what I want in the photo does not fit: most of the Cygnus Wall is outside of the frame. This is better described on Cloudy Nights at https://www.cloudynights.com/topic/896418-seestar-s50-photos/?p=14233868
For the mosaic problem, I found a workaround: I stack the individual light frames in Siril using the script from Deep Space Astro "DSA_Mosaic_Seestar_Preprocessing". My Siril-stacked mosaic is shown at.
https://www.cloudynights.com/topic/896418-seestar-s50-photos/?p=14240306. The final processed photo is in the next message on Cloudy Nights.
I do not use and DO NOT WANT TO USE "Execute enhancement after GOTO" because I first goto a star to check focus. (And note, another bug that has not been fixed: the automatic autofocus bug, I have a good focus setting stored, The Seestar is in focus when it is first started. I do not want autofocus disturbing my focus setting. It also wastes time.)
With the workaround, I can make mosaics but this is still an annoying bug that has not been fixed.
