p099gll When focusing manually, making a change in fast mode made the focusser go all the way in from 7000 to 0. There was no way to stop it. After manually going back from 0 to 7000, autofocus did work
Hello. We recommend that you roll back the firmware, uninstall the APP, re-download and install it, ensure a clean installation, and try again to see if the above problem occurs. If it is convenient, I hope you can record a video to show us the performance further. Please also upload the log after the problem occurs, thank you
