Support@Seestar I didn’t buy $200 in equipment to use alt/az. I’ve enabled enhance after goto and it does nothing to correct the problem. At least now I know it’s nothing I’m doing wrong. You guys are pretty good at adding features and correcting things. So I’ll get 3 hour or so segments of mosaics and use EQ for objects I can center with an off centered box making it literally impossible to use eq mode in any situation until there is a fix I guess? 😂😂😂
ZWO: Here. This is eq mode. Now set it up and good luck finding something that is perfectly aligned with the 50 degree angled box it gives you”
Simple fix. Open the level calibration to accept the degree we are shooting in as level and the machine will work correctly. Bubble that up to the people who didn’t think of it please.
