My ASIAir Mini with v2.4.2 does not work with polar alignment. I tried to revert back to the previous firmware, which I was able to do, except I was NOT aloud to proceed into and use the app unless I use 2.4.2. SO whats the point of reverting back? Why can't I use an older firmware?
When polar aligning, I tried using my iphone, and two different android tablets. Redownloaded the app, reset the airair mini, but polar align just doens't work. It might do the first plate solve, move the mount, then when it tries to take the second photo it just gets stuck on loading. Or, it wont' get that far and it's just a blank screen without plate solving.
I drove 3 hours to my dark site to find out I was being forced to flash a new firmware, that breaks the polar alignment, then unable to proceed into the app with the older version.
ZWO, can you please fix this version so that polar alignment works, and can you please allow users to proceed without updating the firmware? If you choose not to do these things, please explain your reasoning.
