PMTeam@ZWO
I’ve just tested 2.5.2
Mount:CQ350
Main camera: ASI2600MC DUO
Guide camera: ASI120MM Mini (piggyback guide scope)
EAF and CAA.
2600 is powered from battery.
No issues with USB devices so (1 hour)
Polar aligned OK.
select object & GOTO with platesolve OK.
- selecting “object” does not crash in 2.5.2 - that crash was in the beta of 2.5.8
Other issues:
- At present adding a custom object is only possible by creating a PLAN.
It needs a function in PREVIEW and in the Sky Atlas to add a custom object using the current mount position.
- Adding custom objects 1 by 1 is painful. It needs a function to insert a list of custom objects using a delimited text file (eg a table from MSExcel), ideally able to store say 200-300 objects. Not thousands.
Otherwise so far so good. Even got video to work.
