@asiair@zwo#53262
@asiair@zwo#53262 Hello, USB 3.0 will affect WiFi signal. Please keep the USB 3.0 cable away from the antenna or use 5Hz WiFi.
Thank you for your reply
The USB3 cable is not near the antenna and has nothing to do with the issues I'm experiencing with the ASIAIR PLUS in that sense.
As I stated in my previous post...
The problem is that if the camera(s) are plugged in to any USB3 port at startup the device will not recognize the cameras and immediately after completing boot up the wifi is disabled.
If the ASIAIR PLUS is started with the cameras unplugged the device boots up as it should, the cameras can then be plugged in, and all operations are normal, wifi stays connected and STA Mode works 'fine'.
My use of the AAP/ASIAIR PLUS has not changed in the 2 years I have used them.
The cabling of the ASIAIR PLUS has not changed since the day I received it in September as a AEO.
Everything has worked fine.
Immediately after downloading 9.10 these issues began.
There is definitely a issue with the ASIAIR PLUS and its directly related to that update.
Doing a reset or re-install does not work as well.
 @asiair@zwo#53262
 With this corrected information please advise on the procedure(s) needed to fix this issue if you can.
Here's thanking you in advance for your reply.
