Hello Everyone,
I use the Asiar Plus since 1 month, with a Sony A7IV Camera (ILCE-7M4)
At first, it didn't work, like every one, I had some issues with the exposure time (max 30s),
So I decided to buy a shutter release cable :
It was working wonderfully !!! I was able to put the exposure time as I want,
I was soooo happy and had a really great experiences during 1 month 🙂
BUT
Since the new update, 11.01, nothing work's ! 🙁
-> If I use the usb C cable+ Shutter release cable -> "Exposure failed, please check if the shutter release cable is connected properly"
-> If I use only the USB C cable -> Exposure failure
Of course, I tick or not the Asiair parameter
However, I followed all the parameters requested by ZWO...
We talked about this topic on a french forum, where you can see more pictures:
https://www.webastro.net/forums/topic/250906-asiair-avec-camera-sony-alimentation-nomade/
Moreover, before I was able to see the value of the ISO (I could not change it but only see the value)
Since the update, I can't even see it anymore
Same for the Exposure time, before,
Without the shutter realse cable, I was able to put the exposure time until 30s and took a picture,
With the shutter realse cable, I was able to put a free exposure time and took a picture,
Actually it's block at 1s, and I'm not able to took the picture
I also try to do some step back and re-install the 9.97,
It's well install on the Asiar, but the app on my iPhone won't start if I don't update it :
So I have several questions :
- Is it possible to go back and delete this update ? Or to give the opportunity to the user to use an old version ?
- For the Sony user, do you have the same issue ?
- Why it was worked before, and now all is broken ?
I'm very sad and disgusted, because this update makes my product unusable,
[update] And due to the setting of my app store, it's not possible for me to install the old version
Tech@ZWO If you need any informations, feel free ! I can do some tests for you !
Thanks
Adrien
