F6af90IO
Are you using iOS/iPadOS or Android?
Well, I'm in Australia. 1 hour south of Sydney.
I don't use All Sky Polar Alignment.
I don't use the "New Plate Solve" either.
Both of these are in the "i" Settings menu.
I have an ASIAIR Plus 32GB. I use a Samsung Galaxy S22 Ultra running Android 15. I use ASIAIR App - Firmware 2.4 3 - 12.55 (this is the same as 2.4.2 on iOS/iPadOS).
My equipment for unguided EAA:
C8 SCT with f/6.3 Reducer
HEQ5 Pro mount
ASI294MC Pro cooled to 0°C
No guiding. No EAF. No EFW. No CAA.
I did a test a couple of days ago using the normal polar alignment routine.
Polar aligned to a total error of 00°00'20"
Tapped on finish. Then went to Mount Settings > Home. Once mount has settled at Home I then went Mount Settings > Sync Mount.
I decided to check so once again ran Polar Alignment. When it started the total error was still around 00°00'20" +/- 00°00'05"
The thing is you'll see the whole changing Polar Alignment number with SharpCap and NINA (at least from what I've read).
Do a test with NINA's three point Polar Alignment plugin (since it's free) and see what happens.
