Tech@ZWO
Yeah, you guys mentioned this via e-mail. The thing is that I'm not crossing the meridian during the ASPA routine...
I always slew my mount about 80 deg so it can perform the 2 ASPA slews without crossing the meridian, in the direction of the zero position. I have to do this since I don't have a view of the celestial pole (low latitude) (But don't get attached to this, as others have encountered the same issue at higher latitudes). The error still keps changing by itself at every Refresh...
I sincerely don't know what to do. My Mini simply has no use for ASPA. I can only run ASPA with the old V1 with app 1.9.1. Does this give you a hint of what it could be inside the newer app versions?
