If you don't mind using GNU Octave (a free alternative to MATLAB), you can use a script similar to this:
`clear
format long g
x = csvread('C:/Users/XXXXXXX/Downloads/Default_Dataset.csv');
#Change the following values according to your guide settings and AM5 PE chart
guide_rate = 0.5 # 0.5X, 0.9X, etc.
PHD2_sec_per_frame = 2 ;
Xo = 129.60 #degrees at left side of chart (not needed really because we are interested in differences)
deg = x(:,1);
err_asec = x(:,2);
t = (deg-Xo)*(430.82/1.8); #convert degrees to seconds of time
dt = diff(t);
de = diff(err_asec);
deri = rdivide(de,dt); #divide each element of the de matrix by the corresponding element in the dt matrix
max_slope_pos = max(deri);
max_slope_neg = min(deri);
max_slope = max(abs(max_slope_pos),abs(max_slope_neg));
asec_guide_rate = 15.0 * guide_rate / PHD2_sec_per_frame
max_AR_pulse_ms = max_slope/asec_guide_rate * 1000;`
Where the Default_Dataset.csv file has the data obtained from WebPlotDigitizer.
