I have a GEM45 mount and it used to work with the USB hub workaround until v2.3. I updated to v2.3 and now it keeps on disconnecting the mount. I tried different USB hubs, tried connecting via ASI2600. Nothing worked. It would connect for few seconds and disconnect randomly. Wouldn’t start tracking. Tried connecting directly to ASIAIR pro, nothing worked. Really frustrating!
    Hey ZWO--Been playing with the new firmware for a few days now. Wondering if there is any chance you could add the rotation information to a saved target that could even be used for someone without the new CAA. So that when a user revisits a target or mosaic, the plate solve would also help the user get back to the same frame with that rotation info. Anyhow stoked to see the CAA finally here and looking forward to buying one in the new year.
    The PA circle is very small in the new ASIAIR v2.3
    Samsung Galaxy Tab S6 Lite with a display resolution 2000x1200, 240DPI on Android 14
    Not seen in the previous firmware version.
    Old firmware version
      whereisclouds This is entirely irrelevant, the ASIAir isn't running on Windows. It's most likely using libgphoto2, which does support most Sony mirrorless cameras. With that said, using a remote shutter cable isn't the end of the world and it works just fine with that.
      This update has caused an issue with my mount. It uses a Gemini 2 controller. I can PA with no issues. Then I try to return to home position, but it does not move the mount. A window pops up that says the mount has, successfully, moved to home position within 3 to 5 seconds. When I try to use the goto function, a window pops up and says the mount is moving to the designated target and then says it has successfully moved to the target within 3 to 5 seconds, and the target has been
      centered. But again the mount has not moved at all. I can manually control the mount with no issues. Everything worked
      fine before this forced update. Any ideas?
        DeepSkyOne Hi, Thanks for your feedback, I will report this to the developer and they will fix it.
        SRG Hello, we recommend you try the following: 1) Check your positioning and time to make sure there are no problems; 2) In preview mode, shoot, plate solve and synchronize; 3) Try to click "start" Go Home on the mount settings page;
        If you have tried the above operations and GOTO still has problems, please take a screenshot and send us the error log in time, thank you!
        That can be so useful is to prepare a plan or autorun offline.
        Thanks
        SRG your device is what updates the ASIAIR App from the relevant store - not ZWO. Updates aren't forced. You can turn off auto update for the ASIAIR App itself via the Play Store on Android. If on iOS- you can only turn off auto updates for all apps.
        The App on your device has to match the firmware on the ASIAIR itself. They're a matched set.
        So if the app on your device is newer than the firmware on the ASIAIR you are connecting to - it will update the firmware on the ASIAIR to match the App version on your device.
        If you're on Android you can downgrade:
        https://bbs.zwoastro.com/d/18885-how-to-downgraderollback-asiair-app-firmware-with-android
        If you're on iOS then it's a bit different:
        https://bbs.zwoastro.com/d/19176-reverting-to-older-versions-of-asiair-app-and-firmware-for-macos-ios-and-ipados
        PMTeam@ZWO I tried powering ASIAIR via GEM45 mount. Also powered directly from the Anker power station. Not sure why power supply matters. Rest everything is connected, mount is powered on throughout the time, I can see the light and can hear the motor running. I have read somewhere that this is a Kernel issue on ASIAIR, is there any timeline on when will it fixed and upgraded?
          ashutoshv read my post just above yours with links to downgrading the app and firmware to test if you can get it working again with previous firmware.
            PMTeam@ZWO Hi again, I confirm - after shooting in Preview mode and plate solving the Mosaic feature works as expected! 🙂 Thanks!
            However - it would be great to be able to use the Mosaic for planning the session in advance, say, using one of the images stored on SD card. Is it possible somehow? If I plate solve one of the stored images it doesn't show in the Preview screen, nor is its FOV showing in the planetarium (it was always like this, so I'm not saying it's some sort of a bug - it just would be great to be able to setup Mosaic plans in advance).
            Corsair yes I read your post. Unfortunately I haven’t made any backup from previous version and I am on Apple ecosystem so can’t do anything for now. Will do it from next update onwards.
            Having said that, it’s high time @PMTeam@ZWO takes this as priority and fixes the issue once for all
            @PMTeam@ZWO in the next version please add an option in the settings to move the CAA to zero position after the imaging session is complete. It would be especially useful for users with filter wheels.
            SRG SRG did you get a resolution to this? I have a Gemini 2 and have been holding off on updates for awhile. Mike
            PMTeam@ZWO Hello, having a big issue with my 3 ASIAir Plus disconnecting from my iPads after installing latest release and its BAD. My ipads are 10 feet from your AAP’s. Can you please fix whatever you changed. There’s way to really monitor what my 3 telescopes are doing when I can not keep a connection. HELP, and soon please!
            Let your clients know what’s up and fix the bug.
            Thank You
            Jeff Fishman
              When manually entering coordinates and syncing with the mount there is a difference in the longitude but that only happens with zwo mounts. I never had this problem with my SA GTI, it began after I changed it for an AM3. The longitude on the mount always end up being 54” instead of 55”.
                Another bug after updating. When I Move the am5N to point the zenith to take flats (manually using the pad) then the goto home position from the Asiair app doesn't work. It takes three or four attempt or even to switch off an on again to work and go to home.
                  There is an issue with device lock feature: when you set pin with less than 6 digits, its impossible to unlock you asiair! Unlock screen requires 6 digits to input, so for example 5 digit, valid password, results „enter password” message. Looks like major flaw.
