possi "Scan ASIAIR in current network" does not show results when remote connected over VPN. But if you enter the IP manually, it still works (I dont know if its possible to scan remote)
possi switch between 2 ASIAIRS could be so much easier and faster when you already display the available ASIAIRs and let the User simply click on them. Then restart the App without request or unnecessary startscreens.
When using a VPN, the VPN does not broadcast UDP scan packets. So we can't scan your ASIAIR
possi The annoying rotating Startscreens anyway should be disabled by user checkbox (maybe the user can have their own start screen?). Tablet users have to turn their tablets. Especially if the tablet are mount in a fix holder, this is not possible. Forget phones, almost nobody use them.
Are you using the iOS 16 version? iOS 16 does seem to have this issue, and we're also waiting for apple to fix it. Do you encounter similar problems with other landscape apps?
possi If refocus fails (because of clouds), PLEASE at least go back to the last value and continue shooting.
After AF fails, EAF will return to the position before starting AF. However, due to the influence of hysteresis, the real position will not be so accurate.
possi Please make the redesigned buttons bigger. Even on a big tablet they are to small.
ASIAIR App - ASIAIR Settings Page - Personalize - Display Zoom (just for iPad) It will help you~
possi Please make an extra button to enter the object database, I use it a lot. In the "best of" collection please make a "best of including fainter objects" available. Please include the the vDB and the Abell catalogue. For the filter criteria please add minimum and maximum size of an object displayed.
possi Please use for your planetarium a stronger background image (more and fainter nebula visible) and please make a button to turn off these disturbing constellation signs.
Please make user configurable text for the ASIAIR outputs possible (e.g. fan, light, switchbox, observatory shutter, rear heater, front heater, etc.)
Make dithering without guiding possible. I use a high quality mount, mostly without guiding.
In autorun and plan it would be nice, instead of leave the math to the user, if you simply enter the integration time and the single exposure time. E.g. from "18:00-20:00" or "2 hours".
possi For EAF users it would be great if you can bind a default position (maybe also a temperature gradient for users of your thermometer add on) to each filter. Example given: Filter "Halpha" with preset EAF to 45000. Not all filter are homofocal to each other.
Thanks for your advices. We have recorded and discuss them seriously.
