Thank you ZWO for implementing what you have to date. It is welcoming by all and cant wait to see more refinements in the near future.
I have notice a few users have mentioned that they have damage ports from the CAA rotating beyond 180 etc. I understand why the system is trying to do this, but I don't think this solution fits the majority of users.
If your were able to introduces user limits within the 360 range you may find that usrs can let the CAA rotate on flips, but the system will find it will hit users set limits and go back to were it was.
Here is an option to consider
Have a button in the CAA interface to reset the current CAA location to 0 or a button to move the CAA to 0 position.
User will then manually rotate CAA left to desired location and set first limit - via HC or in ASIair app
User will then manually rotate CAA right to the desired location and set final limit. - via HC or in ASIair app
effectively the user is setting a dead zone in which the CAA and can not entre and the system will have the smarts to either rotate the other way or stay in its currently position on flips etc.
The "Dead" Zone is the area where other devices cable port are within.
