Something else I just discovered. I like the filter option in the object list, but turning on the FOV filter results in some messed up results. I'm sorry, but M57 is in no way between 20-80% of my FOV of a 2600MC on a 448mm Cat91! more like 2% maybe (if that). In fact, it ended up showing my only very small things like M57 and the blinking planetary. The filtered list was a very short list of tiny things. And going into the object list instead by tapping the big dipper won't let you slew the mount like it did on 2.3.3. I have to use the Preview menu to slew.
And regarding the object list--the old view has much better thumbnails. The new menu shows you more, but the old menu looked more refined and not like it was written in 1990 (like the new one appears)!
